Reply To: Trouble Filling Gas Tank
Home Forums Bass Cat Boats Trouble Filling Gas Tank Reply To: Trouble Filling Gas Tank
#689568
JB
Participant
The flapper valve does not work.  The flapper itself was not attached to anything.  I retrieved it using a pronged parts grabber.  It is nothing more than a flat piece of plastic.  Here is a picture of it.
The white plastic piece is about 5/8″ farther down in the starboard (failing) side versus the port side.  I’ve attached a couple of additional pictures that may help with perspective.  Here is the port side:
Here is the starboard (failing) side with the flapper removed:
I am the original owner, so I will contact my dealer.
Thanks for you help.
