My master power is not working on my boat. It was working two weeks ago and now nothing. The only thing different between now and then is I changed my 3 Bank Charger. Are there any in-line fuses or breakers that I may not know about? My next step is to check the power into and out of the master power switch.
There is a breaker in the rear within 6″ of the main wire end, on the 12 gauge harness from the terminal block. It is also possible that you did not connect both wires to the battery when you swapped out the charger and missed one. BCB
Thanks I will check it out tomorrow afternoon. My Pantera III is my first boat and I absolutely love it. I will never own anything but a BassCat. Small hiccup but I am sure that I can fix it.
Found the problem. Quick and very cheap fix! Wire came out of connector to the breaker right at the battery. Breaker and wire were laying in the bottom of the hull. Problem has been corrected! Thanks for the help BCB!
