I have a 2008 Classic. It came with rod storage tubes in left compartment. I copied their pattern, mirror image, and made some for right box with only 6 tubes and same hole pattern for butts. Used 1/4 plywood covered with carpet and golf club tubes in front and rubber grommets for back holes. Front part uses 2 pieces of plywood separated by a 1.5″ wide wood strip. This allows you to offset the front one so tubes angle to inside and I fastened in place using this strip. I checked using a tape measure to see how much rod I could shove up the tubes , dont remember the exact number but but 7 is getting close.your boat will be diff if you have the longer Pantera. This allows me to carry 15 rods which meets my needs so far. Good luck.
