Home › Forums › Bass Cat Boats › 2012 Cougar Chine Walking
I recently bought a 2012 FTD Cougar with a 250 Pro XS. When I get it up to about 65 it starts chine walking pretty bad and just gets worse the faster I go. I have not even hit max speed yet as I shut it down before I get there. It has a four bladed Bravo prop tuned by Steves Prop shop on Lake Fork (was on Lake Fork) and a hydraulic jack plate.I also have 26 pitch and 27 pitch Fury props. Would one of them be better concerning chine walking?I sold a 2005 FTD Cougar with a 225 Pro XS and I never had the chine walking problem (or very little). I had a 26 pitch tempest prop on it and also a hydraulic jack plate. Suggestions?
Hi I had the same issue on my 2012 Puma. I was just trimming it too high!! Try full throttle with it trimmed down and just bump the trim up until it hits the top pad . I would try the fury .
You just need some seat time to get it all figured out . — There are some good posts on this site about chine walking . — Just put it in the search bar . — Hoss
Almost any boat with a pad hull will chine walk at some given speed. If your “rooster tail” is higher than the engine cowling, the motor is trimmed up too much. If you have a lot of right torque on the steering wheel when trimmed up, its trimed up to high, or the motor is too high on the jackplate. When trimmed properly and engine height is correct, the steering should be almost neutral. Then, when the boat tries to fall off the pad, generally to the right, you have to make a SMALL left correction…Im talking about a twitch, nothing more. Its not a one time thing, but a relatively constant movement. An unbalanced load in the boat makes it happen more often. My old PII had a 4 blade Eagle Predator prop on it and steering torque was almost completely neutral when trimmed properly. A three blade prop made the torque a bit worse, but not unmanageable. If I had a large partner in the passenger seat, I would have to compensate more…the older PIIs had dual 21 gallon tanks, plus an oil tank, and three batteries, so I would try and balance things a bit by using more fuel from one tank or the other.I dont know what your prop is like, but I LOVED the Predator prop…I was running a 200 Merc XR6 and could get 70mph with two people and a tournament load if I drove it right. But, my normal running hole to hole speed was more like 60mph, just to save a bit of fuel, as the old motors liked gas…2017 Sabre FTD AE DC2017 Yamaha 175 SHOMK Fortrex 80Helix 10 Mega SI in consoleHelix 7 GPS SI GN2 on bow
4,bladed props are generally easier to drive than a 3 blade prop. I would follow the advice given above until you get the hang of it. Good luck.
Read the post at the top of this page. http://basscatowners.yuku.com/reply/178 … ply-178871Big difference between a 225 performance and a 250 engine, plus slippage on the Tempest is a bit more than we usually like. We are not actually Tempest fans on that hull and we have only seen one ourselves run better with a Tempest. That is a standard propeller and it works alright, though the Fury or Trophy is usually better. BCB
True to all above…most likely over trimming.That Bravo should be easiest to drive. Once you get the hang of it slip on the Fury and give it a run.
Thanks for the advice. Ill get some more seat time and try to remember the engine trim issue. On my 2005 Cougar with the 225 Pro XS I never really had to worry about overtrimming the engine. Guess that extra 25 HP (and the prop) makes the difference.
Jeff next time you out at Fork give me shout. I will help you out with the set up.
Mike- thanks I will look you up next time Im on Fork.
