I have purchased a back-up light for my 2013 Eyra trailer and I would like to see where the factory locates these. I am hoping somebody with a factory installed back-up light on a late model Eyra can take and post a couple of pictures of where it is located.Thank you.RobertBassCatSC
RazorCat wrote:This will give you some ideas of location.http://basscatowners.yuku.com/topic/270 … 7qPBWK9KSM Unless your trailer came with the factory installed mounting tabs already welded on then youll have to drill a hole in the top of the rear crossmember. Heres pictures of where I mounted mine.
Perfect! Thanks RazorCat. I was going to put mine in the same area but on the underside of the crossmember (that is where it was on my Jaguar). Now that I see a picture I think I like it on the topside. Protected from road debris, etc. Thank you.Robert
Ive found that if you add the pictures to your album under your Yuku profile its a lot easier to add them to a post. Just hit “Add Reply” and then select “Show Albums”, then choose your pictures to add to the post. Much easier especially on an iPad.
Got hole drilled, primed, and painted. Ready to install and wire light. Which color wire do I splice into? Blue or green? 2013 Eyra if that matters. Thanks, Robert BassCatSC
