I have a 2021 Bass Cat Eyra, 250 pro xs v8, currently 68.2 hours.
Oil was serviced at 20 hrs, lower unit services at 20/50 hrs. Delievered last August, 2+ years warranty on outboard left.
The boat is loaded with nearly every option EXCEPT, padded front deck and stereo
Bobs hydraulic plate, duel power pole blades, hamby, lighted boxes/ alarm. Mercury SC1000 digital gauges. Bass cat aqualon strapless cover (never used) Fiberglass step box, hot foot with slider, aluminum battery trays, stalker wheel upgrade, duel clearcoat ppg on trailer.
Garmin 106/126 echo map sv units, garmin force 36v/100lb trolling motor. Panoptix with perspective mount. gt34uhd/gt54uhd. di and si. Transducer shields. Balzout and BBT mounts.
3- duracell 31agms, one proguide 31 agm cranking battery. DD26 transom saver. SWAG pp mount for stomp pads at bow. Garzon graphics on outboard/ with black-chrome hard badges. I personally installed the mounts and some other things on the boat/ rigging and batteries.
Boat is garage kept and immaculate condition, less some fine marks on the rub rail and some small marks on the skeg. Will come with 24/3 fury that ran 77.8 around 6000 rpms, before I lifted off the throttle. $73,500 obo.
Thinking about going down to a P2 or other bcb model. Boat will be available in July as I need it for a trip in June. – Matt Hayes 7 for more pictures or questions.
