A friend of mine just bought the Classic with a 200 HPDI, he said he is considering swapping from the 25 to a 26 or 27 to see if he can drop the rpms. He is turning right at 6000. I ordered the PII, same set up, and am curious to see what effects it has on his boat. What are your opinions on this set up and about changing the props on his boat? Will the PII perform the same as the classic, I realize I will be a couple hundred lbs heavier. Thanks!Brian
