Home › Forums › Bass Cat Boats › A 10 control panel
Control panel problems the horn and bulge work but the rest do not . Have changed the master switch and the 8 amp push fuse under it and still have same problem . I change the because I used the pump out switch and it worked . So now lose need help
Contact the factory on Monday and let them help. Most offl the staff is in Houston this weekend.
I figured they were. It just says out of stock online. Thank youSent from my VS990 using Tapatalk
