Most of the strips of LED lights in my storage compartments have come loose and seem to stick to everything except where they are supposed to be. Can BCB recommend an adhesive to use in order to get them to stick to the inside of the compartments as intended? Thanks!
I had some peeling on the ends, I put a dab of 100% clear silicone on them, stuck them right back into those little channels. I would think any other type of spray adhesive would be compromised by humidity.
Wipe the back of the light strip and locker area with fingernail polish remover.Than 3m contact cement both sides. Let tack up, than install.So far mine have held in the high heat of Louisiana. Using silicone will also work great.
