You know when you drop a coil ! Holeshot is horrible, spits and sputters, or wont even run at all.I even knew which one was bad by the time i got to the shop !
BamaCat, lets go back to the beginning! Has your boat always run 5000 rpm since you have owned it? Did you buy the boat new? I assume the answer to both questions is yes because of your comments about factory set-up and your dealers comments. If my assumptions are correct, I stand by my suggestion. If the boat was running faster, and for some unknown reason its performance fell off, I would say to let the shop check it out.
The 150 EFI engines are not as stout at the older XR6 models. These usually run well with a 23 Tempest and have more overall performance around 60. Though we see some run better, we shoot for 60 ranges on this application. BCB
09 Sabre,150 EFI,by myself with a light load and 12 gal of gas,23 pitch Trophy,quarter above flush on 8 inch slidemaster,5500,,61mph gps,,no plugs removed,great hole shot,good in rough water.
08 Sabre, 150EFI, by myself w/ light load 23 Tempest Plus – 62 @ 5700rpm. Loaded w/ partner full tanks & wells – 59 @ 5500. This is running in 90+ heat – should see better numbers when it cools down. I was running a 24 Tempest Plus – cool water it turned 64 by myself – 62 w/ partner. Went with the 23 to help with hot weather hole shot and load carrying. Move most of your tackle to rear boxes and only carry life jackets, rain suits, and light stuff” in the front storage.
Well there went my idea of trying a 24 for more speed. Im getting mid 60s gps loaded(not livewell) out of my 23. The flip side of that is Im passing bigger more powerful boats in rough water.
I would chime in with great things to say about the 24 Fury but I have it on a XR-6….apparently it is a different beast. If you can turn it….it is a great prop to run on the Sabre.ElwoodElwood…..Bass Cat Proud
flipit wrote:[/b] Well there went my idea of trying a 24 for more speed. Im getting mid 60s gps loaded(not livewell) out of my 23. The flip side of that is Im passing bigger more powerful boats in rough water.How much bigger boats and motors?
