You can check outgoing voltage on the AMP plug from the rear with probes on a voltmeter. You also can verify positive power is moving, by grounding from the battery and going to the Green wires feeding the pumps, with the positive probe.
Its not always the panels and on a 2009 checking the grounds at the terminal block is a good idea.
