Still have a problem – replaced the fuse. The light is still red on bank three but other two are green, stays red and never turns green, but not blinking. Tested batteries and they are all good. Could the problem be my charger?
It could be the charger, though verify the voltage in that battery as if it gets low the charger will not function. The inboard chargers require voltage in the batts and you may have to boost it with a manual charger to get it kicked off.
BCB is correct again. Id swap the leads off the charger, and if the battery that was the #3 bank blinks, then Id charge that battery manually, then it should work.
