1st check fluid level in batteries, it should be at the bottom of filler hole and at least covering the plates. Use distiller water to fill, 2nd , check connections for corrosion, use baking soda slurry on connections if corroded, then clean with brush3 rd turn charger back on, check voltage with charger on, should be in the 13 volt range
