battery charger went bad, this morning i removed the charger that was mounted on the transom. water is coming from all four screw holes. the question i have is 1. how thick is the transom on a 2010 PIV? the top holes bottom out at 1 1/2 inches and the bottom holes bottom out at 1 1/4 inches. 2.should i remove the engine and jack plate to see if holes where drill through the transom? i am not the original owner so i dont know if charger was factory installed or at a dealership.Last edited by rbcat on May 31st, 2014, 3:43 pm, edited 1 time in total.
