If you are wanting to use Hummingbird units with Lowrance transducers, there is an adapter Motorguide P/N 8M4001962 which will enable the 2D signal to come from the glassed-in Lowrance transducer. then the SI/DI to function from an external transducer at slow speed. Hope this helps.
