Home › Forums › Bass Cat Boats › Bearing Buddy removal 01 sing axle w disk brakes?
Whats the best way to remove the bearing buddy to replace bearings. Then how does it go back on? Its an 01 single axle with disk brakes. Thanks
Ive had success using a hammer and tapping on the outermost edge to work them loose.
yup just lightly tap them with a plastic mallet working around the edges. go back in same waay or just get them lightly started and then use a piece of 2×4 and gently tap back into placeTreat everyday like it might be the last
See the FAQ section.
I couldnt find any thing about this in FAQ just bearing info. Thanks for the help.
