Bilge pumped stopped working. Switched aerator wires to pumps and the pumps are working. All other devices on panel working. Any suggestions? No close place to take for repair. 2007 Puma. Thanks
Had the same trouble with my 95 PII. Turned out to be the ground wire going to the bilge pump. I ended up just running another ground wire to it. Works fine now.
I had a similar problem. The panel on the dash that controls all of the functions was not getting a good connection from the all in one multi connector located on the back. Some of the panel would work at times and sometimes nothing. I found that wiggling the connector on the back would fix the problem but would eventually return. I pulled the connector and put dielectric grease in the connector female ports and have not had the issue return. The dielectric grease can be purchased at any auto parts store. It is commonly used to bridge the gaps in connection to a spark plug boot and spark plug. Hope this helps you KingAir350. If you need help, you can send me a private message with your phone# and I will respond.James
