2008 Puma Boat Horn quit working / The touch pad clicks but no horn. Everything else works on the touch pad but no horn. Do I need to get a whistle. Any ideas. Thanks in Advance.
take the horn out, get the part number off of it, look on amazon and get you another. color doesnt matter because the chrome plate will cover it….problem solved
Agree with scuba on this! Though I would check voltage at the wires at the horn. Get some one to press the button and check the wires for 12 volts with a volt meter. One of the horns should work. Though the 2 on the bcb parts will not interchange with each other.2013 PANTERA 2MERCURY 200 PRO XSMINNKOTA 80LB FORTREX25 fury
If theyre no louder than mine , get a whistle !! — Push the button and it just says eeeep . — No B !! — Need an air tank and a train horn !! — That would get their attention !!
My p2 had a marinco horn. It broke the cover. So I modified and mounted the innovative lighting horn. And it is louder than the marinco for sure. But to be on the safe side with the BLUE LIGHT BOAT. I ALSO CARRY a can horn and a whistle. Surely one will work.2013 PANTERA 2MERCURY 200 PRO XSMINNKOTA 80LB FORTREX25 fury
