prop1501 wrote:
Cajun hunter 67 have you solved your problem yet. If not please call me a 337-380-1437 . Have a good evening.
Ronnie
I have since traded the 24 Fury for a 25 Fury 3. A fellow with a Legend traded me props. Said it works great on his boat.
I am still at work in Nigeria, so I am unable to call. Will get to test it (25 Fury 3) when I return home. If it cures my loping issue, I may send it to you to work your magic.
The 24 you worked was still loping but it did everything you said it would do. Better Hole shot, Acceleration, and it lifted the bow at lower speeds like my 24 Fury 4. Handling was excellent.
I can get the 24 Fury 4 to stop loping if I bump it up very slow and play with the trim. If I trim up quicker (as I did with my other BCB’s) it will slip and drop the bow. I seen 69 Mph with it a few times while home.
Will update this thread as I work thru this issue.
Thanks!
Don
