Starting the install of a LiveScope Plus system in my 2007 Sabre FTD. I’m sick and tired of trying to work with the electrical, NMEA, and network cables without more bow access, so purchased a 6” round access panel and hole saw. It will fit under the MG Toru Pro pedal with adequate room between the rear drain plug and the TM pedal mounting holes, but it’s tight. I guess I’m having 2nd thoughts since reading that most are using a panel in the 4-5” range.
Any reason I shouldn’t use the 6” round panel (7.8” overall) if it fits?
Any help is appreciated.
