BamaCat wrote:downislandliving wrote:Where does the power come from for the bow electronics? I believe they were installed at the factory. Do they go through the rod locker and then back the entire way to the terminal panel that is on the transom? I have a 2012 PII. Any help would be appreciated, trying to track down a problem. Sounds like you are working to wire front electronics direct to battery to eliminate voltage loss. I am working the same issue to run a large wire to the front from one of the TM batteries to reduce the draw on the cranking battery. that is something i am thinking about, i am going to try to find Star 4 way splitter and clean those connections tonight.
