I just received stock on the aluminum parts (lathe turned) for the GPS mount which installs where the front cup holder is.
The kit includes the aluminum disc and crosspiece, 3 stainless bolts, replacement step pad/sandpaper piece and 2 wire nuts.
Installation is simple: remove the cup holder (twist and pull it out of the hole.
Unscrew the GPS puck from the step area.
Cut the two GPS wires and strip enough insulation to wire them back together after passing them through the new aluminum disc.
Bolt the disc in place with the center bolt which goes through the 5″ aluminum cross-bar under the disc.
That’s it, youll have your front step back in action for $100
[email protected] 805-550-7865
