Home › Forums › Bass Cat Boats › Bow Roller
Phil is correct. I prefer the softer black one though. Since they dont last as long, I carry a spare one in my truck, just in case. The black from the roller wipes right off the hull with any cleaner.
Judds answer of notching the rollers is best, though we are hesitant to do a rudimentary cut job on rollers for a new boat. We prefer to do no hatchet work on this at BCB.We also recently this month spoke to a company about a plate with holes for the bow eye for protecting the bow, though that is a project for long term future. The yellow ones impact the bow eye and cause the gel to chip as well as leaving the marking. Though the marking will rub off with your hand and fingers only usually. The black ones do not damage the hull, are softer, last less time, and cost less for replacements. The reason we went back to black was to reduce bow damage from hard loading which chips the gel coat. BCBi copied this from 09 post, anyways i know the black ones dont last as long, i was just surprised to see that yellow one there
In addition, yellow ones have been the standard on new rigs for the past 2 or 3 years now.
PhilAddison wrote:The black one is softer and scratches less, but doesnt last very long. Since it doesnt last as long, some dont notice that it splits/tears and it causes the keel to contact the thru bolt thus damaging keel.Thats what happened to mine, split and the bow made its way through to the bolt and was chipped in two places. $250 bucks to fix the chips!
wow!!, ok i guess iv been sleeping!! sp bcb has the flaking thing fixed?
There is a later post that explains the newer softer yellow rubber with shock veins, which is in between the black and softer than thE solid urethane rollers. Simply put, newer stuff!
Tpop wrote:Has anyone replaced the upper bow roller with boat on trailer? Looks like bunks support boat but “murphys law” could strike at any time.Lot easier to have boat out of the way. Just loosen everything ahead of time. Go to a launch when not a busy time to unload. Take you 5-10 minutes to change them out if have all your tools ready and bolts loosed just a bit.Sent from my XT1650 using Tapatalk
A jack and a board underneath, or a engine hoist and a strap on the bow to lift the boat a little, and the change is simple.
Ive replaced them with the boat on the trailer with no problem if the boat is not tight up against the roller. Usually the weight of the boat is not on the roller.
Another thing you can do that helps. I bought a long bolt that fit where the roller goes, with two nuts and washers sized correctly. With roller out, run bolt through hole on one side and then add a washer and nut and just snug it up. Before snugging, add the second nut followed by the washer. Now with the bolt inserted correctly, you have a washer and nut on the head end of the bolt, then a nut/washer on the other end. Snug up the head end first, then run the other nut out until it contacts the roller bracket. Now with two wrenches, continue to turn that nut and very slightly spread the roller bracket. When you get it right, the roller will fit reasonably tightly without any binding. Remove the bolt and nuts, and install the original bolt and you are done. Do NOT gorilla-tighten the bolt through the roller or you will undo the fix you just did. Now when you pull the boat on, the roller will roll rather than sliding on the hull, and wont leave any transfer of material or scratches…Much easier with boat in water, but you can do it loaded, but might need a floor jack and 2×6 to slightly raise bow to remove pressure from roller during removal/installation…
I bought a replacement from basscat store, but it was a very tight fit. I had someone with a lathe shave about 1/16 off each side. Now Im able to turn it by hand if I want to reposition it because of it being indented or if it develops a rough spot..
That is correct.
I buy the softest roller I can find and replace them when needed.
I always buy my replacements from the bcb store! I had a friend(brother in law) which has a r boat ask me about the stolz. I just needed varification from bcb before mentioning (sticking my foot in my mouth) to him wat i had read.
I used the Stolz outer bells and the BCB roller . — Cut notches in the bells to fit tight to the roller . — Works great .
