I have a 2012 Cougar sitting on a dual axle (torsion) trailer with brakes on 1 axle.
I just received and replaced the actuator, brake lines and 4 torsion axle end units (brakes on 2).
My installation mirrored what was previously installed, I just want to confirm everything was done correctly.
-axle end units with brakes were installed on the rear axle
-brake line is run from actuator down the starboard side of the trailer
-this main line connects in to another section of line that is looped through the trailer frame and connects to the bottom fitting on the starboard caliper
-another line is run from the top fitting of the starboard caliper to the bottom fitting of the port side caliper
Can anyone confirm this is properly set up?
thanks!
