I have a ’14 Puma tandem axle with brakes on both axles. Are the vault axle end units in the basscat store without brakes interchangeable with the ones with brakes? If they are, I assume the non brake one at 1/2 the price may be better for a spare as it doesn’t have the rotor that will rust. Anyone have any pics of a trailer mounted spare hub unit? If you had to swap it out after a failure, is the best option to remove the brake caliper, clamp the caliper piston closed to still be able to use the other brakes, and secure it somehow to the trailer?
Any comments appreciated.
