Duane, To clean out the livewell, just use old fashioned bleach if you have plenty of time between trips. You need to rinse it with 3 or 4 volumes of water after you scrub it down. Plus you want to run your cirulators/aerators with the bleach and without. Make sure you get it rinsed completely. To breakdown the chlorine, you can just add one of the fish saver products and run it real well with fresh water. If you are short on time, probably be just as good to just run a lot of water through it. For the Sabre, it depends a little bit on the ramp angle, but I found that if you back down far enough to wet down all the carpet and then pull back out so that water is up on the fender about 1/2 way it loads just fine. Hope that helps. John
