You can knock it loose. I usually use a small chisel and a hammer, making sure Im putting the force on the epoxy “seam” and not the fiberglass. It should pop right up. Depending on how much epoxy is stuck to the transducer, you may be able to sand it down and reuse, though youd want to be sure the transducer is OK beforehand. Im not sure thats a recommended practice but Ive done it before and had no problems. BTW….Ive had the best luck with the Lowrance fast-setting epoxy for my lowrance shoot-thru-hull transducer installs.
