Ive never run anything but a 3 battery setup in all of my Cats over the years (since 1990), and Ive never had a problem–BUT–I run the biggest 31 series batteries I can find.Im currently running a Northstar 31 series AGM for the 12 volt/cranker, and two 31 series Exide Nautilus wet cells for trolling. Ive run 31 series US Battery and 31 Trojan SCS 225s in the past with great result.If you choose to do this, you must commit to at least three things:1. SS Nylock nuts on all battery connections—tight connections are critical.2. You must plug in and charge all batteries every time you come off the water3. You must monitor and maintain water levels in the two Wet Cell trolling motor batteries. They use more water than most folks think, and if they are allowed to run low, problem will result.Mike Whitten
