C130 wrote:Someone mentioned to me to put a fiberglass resin around the edges of the hole, is that necessary? Same guy recommended some type of seal around the cover, like a piece of foam tape. Is there anything that needs to be done to help seal the cover?I would put a nice champher(break the sharp edge) around the top edge of the hole for sure to prevent small crazing cracks and call it good. As far as sealing with a gasket or foam tape would be strictly up to you! Water goes in that drain anyway even though when and if i do this ill probably make a gasket of some type for mine.
