Home › Forums › Bass Cat Boats › Dash not working
Just took my 2013 Puma out of storage and the bilge button will not light up or work when pressed…manual or automatic. All other buttons work perfect.
I tried unplugging the dash to reset.
Time for a new dash???
I would check the pump wiring connections, and I would also check the buss bar on the transom, as the bilge and recirculate use the normal power wire, and also use a non switched power wire.
There is a post similar to this some where around here with many recommendations.
