What would make a cranking battery loose all current. Last time used was about 3 weeks ago in a tourney and ran live wells all day with no issue. Trolling batteries are holding charge but cranking battery does not show any current at all. Did not move the needle on the volt meter. Excite cranking battery about 15 months old.Any thoughts?Thanks,
Check fluid levels if your comfortable doing so or Take her to an auto shop they will do a quick test and let you know.Practice Angling CPRCatchPictureRelease2010 PIV 200SHO
sounds like something might have gotten left on. Or you could have had a dead cell to begin with and it finally just kicked the bucket. You can probably get a recharge on it, but it wont hold it. Warranty time of time for a new one.
Fluids in the battery are full. If it gets low I replace the fluids with acid, not water. Never had an issue.I will take it back and see if they will pro rate the battery for a replacement. Something is better than nutn.Thanks,
