Check to see if this is a four stem bolt unit, or the Mercury 125 trim pump model. IF it is the stem bolt model we strongly suggest you continually tighten those stem bolts as they stretch. If it is a trim pump model then parts are readily available if you have any issues. Newer SeaStar Detwiler plates are using the SeaStar (Teleflex) pump assembly. BCB
