The Passenger side live well has two plastic covers (screens), turn them counter clockwise to remove. The lower one is where your livewell drain plug is or shuld be. The upper one is for your pumpout or your recirc ( i cant remember which one the pump out/recirc one is), though the lower one i do know is the drain. Some folks dont ever use the plug, just rotate the switch below your throttle to the AUTO position and fill up your live wells as normal. I always use the plug in mine as I dont want to depend on that valve, even though i do switch it over to auto during events. If the plug is in, then I know it is holding the water in the live well. To drain rotate the switch to empty and remove the plug (if you use one), water will then drain out of the back of your boat next to the drain plug. Hope this helps.Last edited by JSLAW on March 2nd, 2009, 3:38 am, edited 2 times in total.
