on a side note however, compression “ALWAYS” seems to be a huge deal, and it is a concern but the leak down on the cylinders should also be a very real concern when checking the motor. my 09 250 optimax has 492hrs w/ 90 psi on each cylinder, which the factory says is still good compression, but the gauge doesnt drop after I stop cranking to check for maximum compression. make sure they check both
