I have an 04 Merc 200 EFI that the engine oil tank is leaking around the cap. Check the cap and it does not appear to be stripped, however, I cant tighten it. I was going to just replace the tank until I saw what the cost was. WOW $75.00 was the cheapest I have seen so far…… for a small plastic bottle. I was wonder if I could just seal the cap with gasket sealer or something like that? Has anybody else had this problem? The oil sure does make a mess and drips for days after I try to clean it up.Thanks guys!!!
