Do all the Basscats have a transducer in the hull at the bow and if so, is it terminated for the Lowrance or Humminbird, or customers choice: Also, here is a pic of the hull from one of Basscats build pics. Can you point/circle the apx area the transducer is located:BTW, to those of you that have a Lowrance terminated transducer installed in the hull and wanting to change to Hummingbird, the sonar adaptor for the “L” series Motorguide will go from the Lowrance transducer to the Humminbird unit.JohnJones Trolling Motor Services870 773 3474Motorguide/MinnKota/PowerPole/Lowrance/Humminbird
