The lines from BCB are ethanol resistant A1 on most models. The Mercury Grey lines are not and those should be your only issue. That is unless someone replaced original lines for some reason? 5/16” lines should do the trick on the 200 EFI.
I’m replacing the fuel selector valve in my 2001 P III. The fuel lines are not stock and I would like to replace them from the tank to the Merc 200 EFI.
Can BCB chime in with the sizes I will need ?
Thanks in advance.
The Mercury Lines are usually grey in B1 or B2 on newer lines, while Bass Cat uses A series and are black. You do not have ethanol lines on older Mercury lines and they are all Grey, new B series and old non ethanol.
