I have 2001 BassCat Pantera III . Two Fuel Tanks. Does the Knob at the rear Marked, “Left” , “Right”, “Off”, have anything to do with the fueling process?? When would it be turned off???? Showdawg
As far as I know, no. Not with the fueling process. It is for tank selecting which tank you wish to feed off of. Left for left tank, right for right tank. Maybe turn if “off” for maintenance to prevent fuel from venting/draining. Beast
Right side tank is just a tad slow taking on fuel, not bad , just slower than the right…. I was curious if the vent had anything to do with it. Showdawg77
The angle of the fuel nozzle is critical, and we have found that if you turn the handle to the inside, pointed at the seat post, that is usually easier to feed those tanks. BCB
