I have a 2008 Cougar with the dual fuel tanks. Do you switch from one tank to the other by using the switch located just in front of the transom? I am assuming the left and right tank switches on the console only change which tank the fuel indicator is reading and those switches dont actually switch from one tank to the other? You must use the manual switch in front of the transom, correct?
