Hey all. I am looking at replacing my factory winch on my 97 p2. The factory one is only a 2 bolt that attches to the trailer. I think its 2 center bolts where it attches. All the fulton ones i see are 3 bolt setup and the center spot is where you slide the head of the bolt through to each side mounting spot so you wouldnt be able to use just the 2. Has anyone run into this before? I know i could go to walmart and get a cheap replacement that is just 2 bolt setup like i have but i would rather but a good unit on there. Thanks for any help!
