Hi guys, As Ive mentioned in a few posts before, Im replacing my dual x15 set up with a x28/x27 setup that I will have networked. I will be sharing 1 GPS antenna between the 2 units. Currently my GPS antenna is mounted in the back, but Id like to move it up to the front. There is a small area up front where the antenna would fit, but its at a slant, so the antenna would not face straight up. I was a little worried this wouldnt work, but while browsing some cats for sale I see Garys boat (which he has for sale) has the antenna mounted here. http://www.impactfishing.com/garyhollander/bow.jpg So the question is (to Gary or whomever), are you ok to mount the antenna flush to the boat at an angle, or should I try and build some type of “build up” out of PVC that will angle the antenna straight up? Gary, do you ever lose signal with the way its mounted here? Thanks Chuck
