Home › Forums › Bass Cat Boats › Heat Effect on NON-BCB Hull??
As many of you know, I have a 07 Puma and 250 XS. My Dad runs my prior boat, which is NOT a Cat but I dont know where else to look for information on this odd deal. Last summer when I was home on leave from Iraq he asked me about some black seapage out of the splash well. It looked like oil or spit-cup water coming out of the drain hole from the splash well drain hole on the drivers side of the boat. Well, the drainage is back and we are now wondering if the boat is safe. Weve never seen anything like this and my Dad has owned bass boats for decades. The hull in question is a 1997. If I was able to put the pics in you should see it draining out in the garage. It looks like motor oil draining out in the pics now that I look like them again. We have always babied that boat and I can tell you it is not oil, spit, dirt or anything from the splashwell. It appears to be coming from within. Any ideas and, more importantly, any safety issues? The boat still runs great and I am concerned about my Dad running the boat if it isnt safe.
Their is water trapped in some wood in the transom and that is what is causing this.
Just a guess but i would try and remove that through hull and see if the transom wood is water soaked it may be rotting. I have seen that color on my boats in the past and it came from the plywood in the transoms. You may get it early and just dry it out and seal it up good.Irv
Check for stress cracks on the transom. Grab the motor and see if the transom moves. Stay out of the stumps!
We fell reasonably sure we know what brand hull that is, and ,if we are correct, they were not known inside the business for their long term construction techniques. A trail of brown water does not always mean a rotten transom, though it does mean there is water in the wood or the hull. Not all brown water is from the wood, and we have seen composite (foam) transoms with colored water. Though in this case we think your father has an issue. We would try removing the rear trim piece and engine bolts, placing the engine on a stand while the transom is allowed to dry. You can leave a hull outside on a very cold night and pull it in a warm to check for moisture as the area with moisture will have a significant temperature difference. Thermal imaging can also be used for sometimes a nominal fee to the effort, and thermal pictures viewed to see the areas. The next step to removing the water is a vacuum pump or rear drainage. As for the transom quality in the rear, that is hard to say. We hope this helps, though our prognosis is not very good. BCB
Thanks everyone. You never know unless you ask. By the way, it is a Champion. Any idea why it only shows up when its hot out?
Had the same thing happen on one I use to own and same brand. Is how I knew what it was also. Believe mine was a 1986 model 181 and was the last year they were built up in Mountain Home. Good Luck
That was our suspicion. Some of those hulls have what is a Balsa Wood transom. We dont know if your fathers is one of those or not, though we are suspect that it is a Balsa transom. Balsa wood is really, really good in hull laminates, even used in Corvette floor boards on some models. Though it is not a good end grain product in transoms. This application is not where you should use it, though they did for several seasons. If this is one of those transoms, then you will be looking at replacement. BCB
Maybe heat accelerates outgassing?http://en.wikipedia.org/wiki/Outgassing
Thats not the first Champion that I have seen do this. Had a friends Champion with same problem. Not sure what it was but they gave him another boat because it was under warranty. I believe the transom was defective in someway due to failure to use proper sealing or something like that.
