I was hoping you guys can help with the installation of a new tandem fender for my 2012 Puma FTD. First, I have the 4 bolts out, and the wiring disconnected. The fender is still on solid, so its evident there is an adhesive on the back of the fender. What is the best way to separate the old fender from the trailer frame? Any tips would be most appreciated. Second, there are no bolt holes drilled in the new fender. I suspect I need to put the fender on, line things up, and then drill the holes for the bolts. Any tips on how to approach this? I was thinking I could use clamps on the front and back and when all looks aligned, I can drill the holes. Again, any tips would be most appreciated. Steve
