I am needing to remove the brake callipers on my 09 Cougar trailer. I am having trouble getting them off with channel locks. Can someone let me know what the trick to this is. I am not that mechanically inclined so a little direction would be appreciated! Thanks in advance!
Those calipers are held on with Allen bolts. I dont remember the size. Recommend getting set of hex bits for ratchet and use extension. There are two black caps covering them. When you get those out, just pull up on caliper
scubaman154 wrote:Those calipers are held on with Allen bolts. I dont remember the size. Recommend getting set of hex bits for ratchet and use extension. There are two black caps covering them. When you get those out, just pull up on caliperThis….
