I have a 2014 Eyra powered by a 2014 Mercury 250 ProXS with Torquemaster gearcase. I am currently running a 25P Fury with (3) extra PVS holes drilled by Mark Croxton. The boat currently has about thirty gallon of gas aboard along with very minimal tackle and two adults with an approximate combined weight of 400lbs. The boat is also equipped with (2) 10’ Power Pole Blades.
I started out with (1) PVS plug in the prop, and it took about 40 seconds to get the boat on plane. I removed the remaining PVS plug and it wasn’t really any better. The only difference was with all the PVS plugs removed, the prop blew out.
What advice can the Bass Cat family shed on this scenario? I experimented with the Atlas Hydraulic Jack Plate at settings ranging from 0-4 with no change. What prop are you guys running with a similar set up 2-stroke Merc)?
