It is a fairly simple process, and the outlet will fit, and the accessory switch on your dash will power it. Pump, fitting, hose and clamps, install and the hardest part is the wiring at the dash and fishing it through the boat. We also have seen a few use the bilge pump switch and just activate the pump out with a separate switch at the rear. Makes wiring simple. BCB
