Thats pretty much what I wanted to say but I wanted someone who is running the same setup to respond first. BassCat has recommended you upgrade you starter battery and use it as the third battery in your system, and that should work just fine for most all of us under normal fishing circumstances.Jim EbarbMany, LA (Toledo Bend Lake)2004 Cougar/ 225 OptimaxHumminbird Helix 12 Chirp SI on BalzOut Mount at bowLowrance HDS 7 at bowHumminbird Helix 12 Mega SI on Ram Mount at ConsoleLowrance HDS 8 in dash at console
