I just got my first BassCat from terrybass76 in Arkansas, and I will have to put new registration numbers on it for Oklahoma. What is the best way to remove the existing numbers? Thanks for your help.
SAMRUSH wrote: Heat gun or hair dryer, should peel right off!! Clean area with wd-40 and alcohol!! Ive also used a heat gun to peel off the stickers, and WD 40 to clean the area. Works great. KentKent Charles 2002 Pantera Classic & 200 Yamaha VMax
We use a hot air gun purchased at Sears. The adhesive heats up and those babies peel right off. Clean the area with alcohol before applying your new #s. Andy Greene Greene Boat & Motor Spindale, NCAndy Greene Greene Boat & Motor 828-286-2290 http://www.greeneboats.com
I used a hairdyer and a plastic windshield ice scraper for the metallic stickers and then cleaned it up with WD40. Make sure that you put a good couple of coats of wax on after you re-apply the new stickers. Good luck ElwoodElwood…..Bass Cat Proud
I used a product made by 3M (I think). I bought it from OReilly Auto Parts. It costs about $30 – $40 bucks and fits on the end of a cordless drill. Talk about peeling the stickers off with no elbow grease….It only takes a couple of mins for each sticker. Ill try to post the name of the product tomorrow.
