You can put in later,and probably should because I know h bird has been back ordering y cables fo awhile now, you can run both to dash and go ahead and use the unit, when you get the y cable just unplug whichever transdeucer you are running put the y cable in the unit and plug both trans. in then. Its easy to change wiring back and forth.
