When I turn the key to the ON position nothing happens. If I turn it all the way to START the motor starts and all gauges work. Key goes back to ON position but everything works.–If I turn the key to just barely past ON (without starting motor) the power comes up and I get the beep and can hear the fuel pump prime. It does this every time I try it.If I let the key go back to ON everything goes off. Smart gauge says lost engine connection and then turns off.–If I turn the key to ON and just let it sit – sometimes after a while power comes up, sometimes it doesnt. If I jiggle wires to swich sometimes power comes up, sometimes it doesnt.–I unplugged the plug to the switch to look at the connects and all looks clean and fine.Im pretty sure I need a new ignition switch but wanted to check in to see if there may be anything else to think of.If I need to change switch it appears I just unplug the old one and plug in the new one. I unscrewed the nut on the outside of the switch but couldnt move it out of the hole – I didnt try to force it. Will just a slight tap break it loose?Last edited by 1958 on August 30th, 2015, 3:17 pm, edited 1 time in total.
